- 77
- 74 小时
- 2019-8-28
- 50
- 211904
- 77
- 77 点
- 77 ¥
- 2010-6-17
楼主 |
发表于 2010-6-25 13:06
显示全部楼层
存点网上找的资料:
http://www.erji.net/read.php?tid=78819
看到这么多网友能用上FOSTEX全频喇叭,真是高兴,我是去年11月购买FE166的,在制作过程中也遇到不少问题,也收集了不少资料,在此与大家分享一下,也作为多年来曾受到众多素不相识的网友们的帮助的一点回报。提供的资料如有错漏,请不吝指正。
1、FOSTEX喇叭单元用的箱体用什么材料好?
Fostex厂家推崇制作箱体的板材
其实,密度板和多层板都是夹板的一种,而Fostex厂家推崇制作箱体的板材就是夹板.不信?
那就请看看这里吧!是由Fostex厂家原文翻译的
原厂推崇:
Enclosure materials
Among the many types of materials available even for general consumers, plywood will be the best choice in terms of price, processability and acoustic characteristics. Typical easy-to-obtain plywood types are presented below while many more are available.
外壳材料
在普通用家也能找到的许多材料中,夹板是最有性价比,可以方便加工和具有良好声学特性的选择。下列就是常见的典型夹板种类,当然其他选择还有很多。
(1) LAUAN PLYWOOD
This plywood is one of the most widely available plywood. Plywood of lauan, which is a tropical wood, is commercially available in various thicknesses. Its appropriate level of rigidity makes this material one of acoustically excellent candidates. Only solid plywood should be chosen for enclosure production purposes.
1,柳桉木夹板
这是最被广泛使用的夹板。柳桉木,一种热带树木,做成的夹板在市场上可以找到各种厚度。这板硬度合适,是声学应用最好的可选材料之一。只有结实(实心)的夹板可以被用于制作箱体。
(2) LINDEN PLYWOOD
Linden plywood is generally lauan plywood laminated with a linden veneer. With a surface smoother than that of lauan, and with very acceptable appearance, this type of plywood is a good choice for aesthetic acoustic applications. Plywood made only of linden is too soft for acoustic applications.
2,菩提树夹板
菩提树夹板通常是作为柳桉木夹板的表面修饰,因为菩提树夹板比柳桉木来得更平整,并且外观非常好看,这种漂亮的夹板也是声学应用的好选择。当然纯菩提树制作的夹板就太软了并不好用。
(3) OREGON PINE PLYWOOD
This soft plywood made from North American trees is characterized by reproduction capability of high quality sound. No materials other than this may be appropriate for enclosures where advantages of enclosure vibration is positively intended to be taken.
3,俄勒冈州松木夹板
这种柔软的夹板源自北美的树木原料,能够再现高质量的声音。作为箱体材料,这就是最佳选择了,这种材料的优势在于它的箱体振动能对声音带来积极的影响。
(4) LUMBER CORE MATERIALS
This material is composed of glued-up square-cut wood, and used as the base material, with a surface material sandwiching the base material. Often laminated with linden material, this plywood is rather soft and, occasionally, has a hollow structure. This structure makes these materials acoustically unsuitable. If its use is still chosen, candidate materials should be closely inspected whether to have a suitably high density structure.
4,素材心板(木芯板)
这种材料是将木材压方贴合而成,外加其他的表面材料而成为三文治结构板材的内部基料。常用的表面材料则是菩提树料,这种夹板非常软而且有时候结构不紧密。这种结构是的这些材料不适合声学应用。如果没有其他选择,必须仔细检查侯选板材的结构,确保有较高的密度才是。
(5) PARTICLEBOARD
This product is made of glued and pressed wood chips to form sheets. Bonded chips using adhesive are extremely hard and heavy. The use of large sized chips makes these boards unfit for screwing or nailing. Also, an attempt to glue these boards together will result in difficulties. In this respect, it is not very adequate for the general public to process, compared to most other materials.
5,木屑板
这是胶合压制木屑成型的板子,带粘合剂的胶合木屑非常坚固,重量十足。如果使用的木屑体积较大,则板子不适合用于上螺丝或者钉子。而且,粘合这些板子是非常麻烦的事情。这就导致了,相比其它大部分板材,木屑板并不适合大部分用户自己处理加工。
(6) MDF (Medium density fiberboard)
Like particleboard, these products are also glued and compressed under heat. What makes this material differ from particleboard is that this MDF is made from very fine wood powder. This construction permits use of wood screws for ease of processing.
6,中密度板
和木屑板一样,这些产品也是高热状态胶合压制而成。它们之间的区别在于,MDF用的是很精细的木粉制成。这种构造可以使用木镙丝,方便加工处理。
(7) LAMINATED WOOD BOARD
These are boards made up of glued square-cut pieces of wood. Nowadays, use of many types of choice woods is possible, and subsequently, excellent sound, thanks to the availability of such choice natural woods, can be enjoyed. However, the physical property inherent in such natural woods, such as its likelihood to warp, remains present even after they have been made to form enclosure components, resulting in occasional distortion or cracks in enclosures.
7,叠层木板
这些木板是由木材压方粘合而成。如今,有很多精选木材类型可以被选择,而且这些精选的天然木材能带给我们超凡脱俗的声音享受。然而这些木材的天然特性,比如可以被扭曲,就算成为了箱体组件也还是能体现无疑,也许会造成箱体变形甚至破裂。
Top of Page
Assembly of enclosures
No more than mere cutting materials to predetermined dimensions is necessary before assembly of enclosures. However, bonding options are abundant. The most often used bonding means is the use of the ?eplain joint' method. In addition to means using ?etenons or grooves' prepared prior to assembly work, this ?eplain joint' is another very effective method. For assembly, wood work adhesive is used. Unlike bookshelves or chairs where nails or wood screws are a main bonding means, wood work adhesive is the key component in assembling enclosures. Wood work adhesive is an effective means for maintaining tight seals between bonded surfaces. Application of a more than sufficient amount of adhesive, followed by immediate wiping of extra adhesive, squeezed out from member meeting surfaces, will permit neat and tidy finish. The temporary use of nails, wood screws or sash clamps for glued portions before the adhesive sets will ensure formation of strong and solid bonding. Should the structure provide removability of the back board, or some similar ideas are incorporated, used of packing (e.g. gap filing tape) is highly recommended
2、箱体类型选择:
1.背负载号角箱(见原厂图纸,或到以下网站下载PDF文件);
http://www.madisound.com/fostex.html
2.TQWT箱体(见贴图);
3.倒相箱(见原厂图纸,或到以下网站下载PDF文件)
http://www.madisound.com/fostex.html。
4.开放障板(见附图);
5、“蝌蚪”型音箱(见附图)
低音量感:从大到小 1>2、5>3>>4
低音反应速度:从快到慢 4>5>3>2>1
DIY制作难度:从难到易 1>5>>2>3>>4
台湾和日本有网友用“蝌蚪型”箱体,据说中低频反应速度很快,量感也较多。
对于购买了FE103E/107E的朋友,台湾的网友colin认为:“103M 簡單的話用一塊 60 x 60 的幛版,便宜效果又好,C/P 相當相當高。”这很容易DIY,给个其他单元用的开放障板图纸参考(把喇叭开孔变成FE103的尺寸即可),见贴图。
上面两个图分别是实作和图纸,用的单元是著名的DIATONE 610.
另外,本人还有一个方案供大家参考,但需要自己去实践:就是找两把二手的一样的“吉他”,把FE103/107装到吉他共鸣箱的音孔上去即可,如果想效果更好,就是增加倒相孔和倒相管,但具体尺寸需要去实践调试。吸音材料也需要自己去试验调整。
3、怎样“煲”喇叭?
先看两篇文章:
““煲”喇叭篇
我们经常会听说新机器喇叭要先“煲”一下才会好听,甚至还会有些“煲”了一排器材的声音比新机时可以话是“天翻地覆”。
喇叭主要是“煲”纸盆和盆边的胶边、分音器零件,和线圈的铜线部份。通常新的喇叭纸盆和胶边会比较紧,使得发声时比较紧,所以听起来音场不够开阔,低音不够自然,响应也较差,分音器中的电容器也会因为久未充足电而效果较差,甚至有说,连接的铜线通电一阵子后才会比较顺是因为铜中的自由电子活动比较快了。
“煲”喇叭时,如果您常年只是开小声来听,那就不太容易把喇叭“煲”得很好。大家可以用吸音较强的如棉被之类的把它包起来,也可以把两声道的喇叭相对,把其中一声道的喇叭线正负反接,会抵销一部份的音量。同时要选用较大功率的扩大机,以免开大音量产生削峰而损坏喇叭,音量要开得够大但使喇叭不致於快承受不住。
特约作者:JIM”
“如何將喇叭“煲”出靚聲來
我在音響展時,經常碰到客戶要買展示中的擴大機和喇叭,甚至連喇叭箱体因碰撞外觀有點瑕疵,即使原價他也要買,歸究其原因大概有下列兩點:
他們認為廠商所展示的器材,大部份多有修改過,而且用料一定比賣給客戶的來的猛。( 題外話:有關此點,我相信絕大多數的廠商都不會這樣做,像我們的展示器材都是隨便挑的 )
我們經常會聽說新喇叭要先”煲”一下才會好聽,有些人是想要省下 Run 機的時間和功夫,他可立即享受這個器材應有的音色水準。
就以我們的”真空管綜合擴大機搭配桌上型喇叭”音響系統而言,擴大機不用煲,不過根據很多用過的客戶與我個人的經驗,管味在 30 分鐘後會更濃,有關此點或許各位可親自體驗一下。至於桌上型喇叭,我是建議一定要煲,其實喇叭是否需要煲,要看這喇叭的品質,假如您的喇叭品質不怎麼樣,就算您煲的再久,音質也不會變好的。今天我們在這篇要研討就是如何將拿回去的新喇叭Run出靚聲來。
一、”煲”喇叭
”煲”,外國玩家稱之為“Run In”,指的是對音響系統進行長時間的連續使用,讓喇叭箱的單體老化,使之不再發出刺耳的噪音,並讓聲音有最大限度的圓潤、甜美。許多玩家把“煲”機比喻為開新汽車,使各機械零件經過一段時間的磨合,達到最佳的工作狀態。有人說:煲機有如打通七經八脈;喇叭主要是“煲”紙盆和盆邊的膠邊,分頻器零件 ( 電容電阻等 ) 和線圈的銅線部份。通常新的單體紙盆和膠邊會比較緊,相對地聲音就比較緊,音場不夠寬廣,聲像定位能力稍差。
二、如何”煲”喇叭呢?
當您拿到新喇叭時,它的聲音絕對沒有原款的舊喇叭來的好聽,那是因為他的聲音還沒全開,此時您必須“煲”喇叭。一般的上班族,下班回到家能聽音樂的時間最多 2~3 個小時,而且多在晚上,音量也不能開太大,這種小小的音量,再聽多久效果也不會太大,建議您利用例假日的白天好好煲一下。現在就以我們這一套組合的系統來講,音量大概轉到一點鐘的位置,至於實際的位置,您必須依照您實際狀況來調整音量,原則上聲音要稍大但不要失真太多,所播放的曲子要高、中、低頻的音樂都要播放,假如各位手中有音響展送的展示片,可以選幾首高、中、低頻的曲子,以 CD 唱盤重新編輯順序,再按 repeat讓它一直重複播放。其實正確的“煲”可以更全面、平均地活動音頻系統的全頻段 ( 人耳能聽到的聲音頻率範圍:20Hz~20KHz )。也就是說,即使已經使用了很長時間的喇叭,在經過正式的煲機程序之後,仍能有較明顯的改善,這是因為我們常聆聽的音樂,其頻率並不能涵蓋由超高至超低的每一段頻率。我們的桌上型喇叭是一款中、高、低頻都相當好的喇叭,尤其低頻部份,煲前煲後會有很大的差別,不信您可以親自體驗一下。
三、如何選曲呢?
打通全頻段同時兼顧音樂性的培養:發燒碟中的古典音樂、大型交響樂、進行曲。
高頻:慕特的流浪者之歌、阿卡多的小提琴演奏系列等。
中高頻:“梁祝”、“二泉映月”、維瓦爾第的“四季”..... 等。
中頻:以蔡琴的“機遇”、騰格爾的“天堂”等鍛煉音頻系統的厚度、細膩度和質感。
低頻:鬼太鼓、Eagles ( Hotel California ) 、RR公司的 ( 科普蘭百年紀念 ) 和紅魔鬼。
以上的所列的曲子是大家比較熟的,其實在選曲時,不光是注重它的音樂性,更要考慮兼顧全頻段,可別陷入音樂的美妙的旋律中,而忘了自己的任務哦!用自己常聽的音樂進行循環播放,使相應頻段收放效果得到進一步增強,更加得心應手。相信大家都有偏愛的作品,不過值得注意的是歌曲的數量、種類應盡量豐富一些,而不是拘泥於某種類型的某個曲目,如此煲出來的喇叭才是全音域的喇叭。
四、煲喇叭的方法
用吸音較強的材料,如棉被之類的物品,把音箱包起來,以吸收惱人的噪音。
將左、右兩只音箱以面貼面,相位相反的方式相對放置 ( 喇叭上下座對調 );這樣會抵消很大一部分的噪音 ,而單體的活動幅度依然不變,貼得越近噪音越少 ,還可以取得相當不錯的整體效果 ;但如果音量太小的話, 其聲音靜噪不能去得很乾淨,達不到理想的效果。所以設置恰當的音量在煲”喇叭工程中是一項重要工作。
五、煲多少時間?
需要煲多久呢?傳統的喇叭“煲”的時間均要求在數百小時左右,一些要求較高的發燒友更是花了大量時間、精力在上面;以我們的組合音響系統而言,我個人認為 100 小時左右就好了;其實這並不是一個硬性的規定,大家可以靈活掌握,不過最初階段最好每次開機在12小時以上,這樣可以更快地展現出效果,如果每次 Run In2、3 小時就休息的話,會使效果大打折扣;此外每隔 2、3 天最好實際聆聽一下,以掌握其進度,作好適當的調整。總之,只要有持之以恆,美好的“靚聲”會來向您報到的。”
4、我是怎样“煲”FE166E的
(趁有空赶紧写了吧!)
(1)刚开始我是严格按照楼上的两篇文章的指导去煲FE166E喇叭的,因为得来太不容易了。
要知道当年(也就是2003年8月,^_^哈哈)我是冒着生命危险(音响是我生命的一部分),先交了300大洋订金,苦等了两个月,终于台湾产的FE166E从日本飘洋过海到了香港,再舟车劳顿在2004年10月到了广州,交上1000大洋尾款,60大洋邮费保险费后,FE166E才上了NB的中国邮政车到了我处,。所以我是多么羡慕你们啊!
言规正传,刚开始我是用CD机,晶体管功放(胆机不舍得啊!其实CD机也是不舍得的!),用适当音量(主要是使喇叭单元的振幅在1mm内,因为FE166E有一项指标Xmax为0.6mm),CD碟用《无线电》附送的音响测试碟,用33Hz、60Hz(具体数字不一定对,总之是用100Hz以下的几个低频频点TRACK用“REPEAT 1"功能连续煲喇叭(指FE166E单元,下同)2~5小时,因为心疼CD机,不舍得播放太长时间,后来用粉红噪音TRACK、白噪音TRACK煲。后来还是太心疼CD机了,就找了一台FM收音头,调到没有台的频率来取代白噪音信号继续煲喇叭。总共低频50小时+粉红噪音50小时(此时我心如刀绞啊!!!我的CD机啊……)。白噪音100小时(用FM收音头做信号源)。
(打字打累了……,一会继续)
DABEN 2004-10-28 16:55
快上,正上瘾
wongzh 2004-10-28 17:15
(2)不心疼的煲喇叭方法:
首先,你要把FE166E看成是100元买回来的,“煲”坏了就不要了!其实FE166E没有那么容易坏!!!不要太紧张它。
我手头上刚好有一胆机用电源变压器,总功率150W,其中有一5V/2A绕组(玩胆机的朋友都知道这是一电子管灯丝绕组),还有一只200欧姆/50W的可调电阻,于是我把一对FE166E反相串联,再串联上这个200欧姆的电阻(把这个电阻的阻值调至最大值),再直接接到电源变压器5V/2A绕组上,然后接上220V交流电源就可开始“煲”喇叭了,开始让喇叭的振幅在0.5mm内,“煲”24小时后再调节200欧姆可调电阻使FE166的振幅<1.2mm即可。我在FE166喇叭振幅在1mm左右的状态下连续煲100小时没有问题,此时单个喇叭接线端子上的交流电压在2.1伏左右,本来想继续煲再长一点时间,由于有四天没有音响听而停止了。
两个喇叭单元是如附图所示叠放在一起,下垫有吸震材料,两喇叭是反相连接,这样噪音最小。
煲完后你会发现喇叭出来的声音会更加轻松一些,没有以前那么“紧”,也就是所谓的“脱箱感”更加好了,你会感觉声音不再局限于两个音箱之间,声场变宽了。
wongzh 2004-10-28 17:27
(续上贴)
其实按我这种煲喇叭方法是可以连续煲200到300小时的,而且应该是安全的,关键在于分压电阻功率要足够,否则发烫烧毁后果就严重了,另外变压器质量要好,不能在使用时发烫,最重要的是FE166的纸盆振幅不能过大,个人建议<1.2mm。
(好累,明天继续吧!)
leath 2004-10-28 18:54
好贴,可用220v的电源煲只是煲50hz频段啊,这样煲后低频响应应该不错。
楼主还有什么好东西,一并倒出来吧,多谢啦。
xf_112 2004-10-28 22:32
我还是慢慢来,边听边煲算了
wongzh 2004-10-29 08:44
TO leath、xf_112 :
对喇叭而言,我个人认为煲低频主要的目的是老化喇叭的悬边、布弹簧,用低频来煲应该是效果最好的,尤其是全频喇叭单元,全频单元听小编制的音乐为主,小编制的音乐低频成分较少,如之前贴的文章中所说:“一般的上班族,下班回到家能聽音樂的時間最多 2~3 個小時,而且多在晚上,音量也不能開太大,這種小小的音量,再聽多久效果也不會太大,建議您利用例假日的白天好好煲一下。”
至于煲的时间长短,我个人经验是每次持续长时间(10小时以上)为好,喇叭振幅控制在它的最大线性振幅附近。打个不恰当的比喻,比如你去烧开水,如果每次都是用小火烧5分钟,那么你的水只烧到70、80度、是永远烧不到100摄氏度的。我只是给出一种方法,具体的操作自己灵活掌握才是正确的做法。
如之前贴的文章中所持观点我是比较赞同的:“需要煲多久呢?傳統的喇叭“煲”的時間均要求在數百小時左右,一些要求較高的發燒友更是花了大量時間、精力在上面;以我們的組合音響系統而言,我個人認為 100 小時左右就好了;其實這並不是一個硬性的規定,大家可以靈活掌握,不過最初階段最好每次開機在12小時以上,這樣可以更快地展現出效果,如果每次 Run In2、3 小時就休息的話,會使效果大打折扣;此外每隔 2、3 天最好實際聆聽一下,以掌握其進度,作好適當的調整。總之,只要有持之以恆,美好的“靚聲”會來向您報到的。” |
